Air bag valves
Is anyone running manifold style valves like this? Any pros or cons to them? I see a lot of pros, just want to hear about the cons :)
Thanks for the input. http://cgi.ebay.com/ebaymotors/MANIF...item1c16dda669 |
Re: Air bag valves
I've heard that when one valve goes the whole assembly is junk.
Re: Air bag valves
The concept alone should be apealing to most. I like the idea that its all neat and organized.
Re: Air bag valves
Using the term "AIR ENGINE " to describe it makes me think of AIM/Chassis Tech. If that is the case then do extensive research on AIM, Chassis Tech, airbaggit.com or whatever alias they are hiding behind this week.
Re: Air bag valves
Re: Air bag valves
It all seems to be the same place. Im just looking for people that are using them or have used them and see what they say. Im leaning that way and I found a wide range of prices.
Re: Air bag valves
If you go with the Air Ride Tech or AccuAir manifold you will have many many years of trouble free use and yes they are serviceable to boot!
Re: Air bag valves
My friend is running the accuair manifold in his caddy. The biggest pro is a clean and more simple installation with the plumbing and wiring. It's only been a month since the install, and it's been trouble free so far. IMO, the valves in a air suspension system isn't the place to try and save money on...to much "riding" on em if you know what I mean.
Re: Air bag valves
agreed... it always amazes me when I see the word cheapest when it comes to suspension LOL best deal on a part yes cheapest NO hahahahaha
Re: Air bag valves
Understand, im just talking about the style, not the price. Im a fan of you get what you pay for. A median price for these are around $400.
Re: Air bag valves
Re: Air bag valves
Re: Air bag valves
Re: Air bag valves
I just used that as an example. Im going with 3/8 valves. I have also priced out single valves too. That what I did for my 65, but I only had front and rear seperated(4 valves total). I wont do that again.
Re: Air bag valves
Re: Air bag valves
yeah we only used 1/4 ride pro or 3/8 big red at A.R.T no 1/2
Re: Air bag valves
if yall want manifolds for around $400 look at asco's.
I sell them all day every day. Awesome valve. and a little FYI, ART big reds are basically Asco's, for 435365756x the price. |
Re: Air bag valves
Accuair=YES
Airbagit.com=junk |
Re: Air bag valves
The big red are not ascos they are a bubble tight valve designed and built specifically for A.R.T by parker and are a bubble tight valve along with the ride pro valves which has a zero leak down tolerance unlike many others that have an alotted leak tollerance
Posted via Mobile Device |
Re: Air bag valves
Thats good info to know.
Re: Air bag valves
funny how if you order enough ascos you can get custom colors and engraving....;) |
Re: Air bag valves
Re: Air bag valves
Re: Air bag valves
or are you trying to justify all the money you spent on ART gear? ;) |
Re: Air bag valves
I don't need to to justify anything. I bought ART products because I wanted quality and don't mind paying for it. I can't tell you anything about whats inside the valves because I have never had a need to take mine apart.
Jon on the other hand spent several years working for Ride Tech, so I can safely speculate he knows a bit more about those valves than both of us combined...:) |
