-   -   Cracked Frame (https://67-72chevytrucks.com/vboard/showthread.php?t=430146)
killer86 11-09-2010 06:10 PM
Cracked Frame
The frame on my 86 is starting to crack around the steering box area, what is the best way to get this fixed?
hugger6933 11-09-2010 06:13 PM
Re: Cracked Frame
grind into the crack with a die grinder then wire weld up the crack grind down the excess bead . Jim
babyJay 11-09-2010 06:20 PM
Re: Cracked Frame
After you get it welded there are reinforcement kits you can by to put on there, I remember reading about them once.
tantrumpipeline 11-09-2010 06:43 PM
Re: Cracked Frame
check out coloradok5.com i think off road design builds a kit for this
LONGHAIR 11-09-2010 08:10 PM
Re: Cracked Frame
It's a pretty common thing and yes it can be repaired. "How" depends upon the severity of the cracking.
monza1979 11-09-2010 08:15 PM
Re: Cracked Frame
ORD makes a great kit for frame repairs in this area http://offroaddesign.com/catalog/steeringkit.htm i built my own and am in process of boxing in that section of the frame for more durability.
1BadSS 11-09-2010 08:36 PM
Re: Cracked Frame
LMC sells a reinforcement kit for our trucks.
