-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   70 4x4 chevy pu axles vs 71 4x4 blazer axles (https://67-72chevytrucks.com/vboard/showthread.php?t=43154)
70Chevy4x4Nut 03-04-2003 04:40 AM
does anyone know if there were any differences between front and rear axles/housings used in 4x4 trucks vs those used in 4x4 blazers. Were some heavier than others. Both are 1/2 ton models.
I am restoring a 70 4x4 and I purchased a 71 4x4 blazer donor vehicle for parts. The blazer has front discs which I will use. I don't know whether I should replace the whole assembly or just remove the discs. One thing that might have a bearing on this is that the blazer has a detroit locker in the front. I would want to swap that out too. The gears on both vehicles are 3.08. And what about the rear? neither one seems to be posi in the back, yet I don't know if the axle housings are of the same construction. I have not compared the drum sizes yet. Want to check axles and see if maybe the blazer had any modifications done to the rear. Anything in particular I may look at?
Any knowledge on any of this?
Thanx again
BLAZIN'72 03-04-2003 07:03 PM
As for the front i would just do the swap. It's heavier work but not as much, especially if you want that posi. As far as the rear goes chevy lists 2 different part numbers for 67-70 - 71-72 for rear drum shoes, so the drum size could be different between the two but the housing is the same. I would remove the rear diff cover of both and inspect the ring & pinion of each and roll with wich ever one looks fresher.
JIMs70GMC 03-04-2003 07:19 PM
Both rears should be chevy 12 bolts. For the front as was said just swap the whole front axle.
70Chevy4x4Nut 03-04-2003 10:58 PM
Thanks guys. I will use your suggestions.
