1972 c10 drop
What is the easiest way to lower a 1972 c10 lwb without c notching the frame. And i want a even stance.
Re: 1972 c10 drop
how much do you have to spend? how low ya wanna go?
Re: 1972 c10 drop
Easiest and cheapest,... is a spring drop.
The lower you go,... the more is costs. Spindles up front are the best. You can use up to a 6" rear drop spring without having to notch the frame. |
Re: 1972 c10 drop
so if i got springs for the back and drop spindles for the front would that work or would i need springs up front too.
Re: 1972 c10 drop
Adding springs is up to you. How low do YOU want to go. A 4/6 drop is about the max "streetable drop". |
Re: 1972 c10 drop
do you have rear leafs? not to hack the thread but i want to do the same thing on the same truck...how to go the lowest w/o notching...not opposed to bags, especially if i can use them down the road if/when i do notch.
SO GIVE IT UP FELLAS....what are the best parts/pieces/vendors to use to drop these? |
Re: 1972 c10 drop
ECE
(www.earlyclassic.com) |
