-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   need traction (https://67-72chevytrucks.com/vboard/showthread.php?t=434445)
3r!c84 12-06-2010 09:56 PM
need traction
not hooking up at all. just spins the tires like nothing.. it would be fine if i just wanted to show off and burn the tires but i want to hall as$
what is some things i can do?
caltracs
slapper bars
exc.
btw im running 315/35/17 tires in the back.. posi is on its way in a few weeks that will help but will still burn them both like nothing..
http://i995.photobucket.com/albums/a...9/f49affbe.jpg
need to get rid of this.. :lol: :waah:
http://i995.photobucket.com/albums/a...9/d9f3013d.jpg
N2TRUX 12-06-2010 10:14 PM
Re: need traction
I have heard great thins about CalTracs. That would be my first choice "after" the posi.
3r!c84 12-06-2010 10:20 PM
Re: need traction
any links to a kit. truck has a flip kit too
875.3CHEVY 12-06-2010 11:59 PM
Re: need traction
dont know how to link but its off 73-87chevytrucks.com
http://store.73-87chevytrucks.com/me..._Code=7387SUSP
3r!c84 12-07-2010 12:11 AM
Re: need traction
holy cow $$. any other tips on traction.
875.3CHEVY 12-07-2010 12:23 AM
Re: need traction
my truck has a flip kit too and i was thinking bout the older style traction bars.the kind that look like a piece tubing and a snubber could be made to work since the rearend isnt in the way anymore.
3r!c84 12-07-2010 12:39 AM
Re: need traction
right but isnt that for axle rap? i dont think mines raping. its not jumping or hoping. its just spinnggg
875.3CHEVY 12-07-2010 12:49 AM
Re: need traction
all traction bars work the same.they use axle wrap to plant the tires/lift the vehicle.caltracs are just adjustable.
3r!c84 12-07-2010 12:52 AM
Re: need traction
ohhhhh ok i get what your saying.
3r!c84 12-07-2010 01:05 AM
Re: need traction
what about this? http://www.summitracing.com/parts/LAK-20475/
Captkaos 12-07-2010 01:11 AM
Re: need traction
Caltrac will help, but you need to be planting both tires.
I sell the caltracs because they work. you can get flipped or non-flipped.
Re: need traction
Those in summit are a waste of money, they aren't long enough to work correctly.
3r!c84 12-07-2010 01:15 AM
Re: need traction
yea i was thinking thos where junk lol have you put them caltrac's on any trucks that are putting down some good hp numbers? how did it react before and after the install
this truck is going to see the strip as well as the street
875.3CHEVY 12-07-2010 01:15 AM
Re: need traction
thats what i was refferin to.just need to make sure theyll work.they need to be long enough.the snubber needs to contact the spring eye.make sure you have enough room as to not have them below the edge of your rim.and make sure their wide enough for your springs.they have them for stock trucks but flipped they hang to low.
3r!c84 12-07-2010 01:18 AM
Re: need traction
very true thats also one of my problems being lowerd
Super73 12-07-2010 02:43 AM
Re: need traction
In this order..
Posi
Drag radials
Caltracs
Different front springs (Long with a very light spring rate to store energy)
Adjustable front shock
Adjustable rear shock
Possibly a different rear leaf
3r!c84 12-07-2010 08:16 AM
Re: need traction
want to launch like in your picture
Captkaos 12-07-2010 01:43 PM
Re: need traction
The 2000 Silverado my brother owns that had a stock 6.0L/4L60E,remote STS Turbo, 10bolt with 3.42 and Eaton posi and caltracs is running 1.65 60ft times on ET drag slicks. caltracs controls axle hop and gets it out of the hole better. Popped the motor before he started adjusting it.
It was dyno'd at 600hp/798tq at the tire.
edit: figured I would add that when he started he was running 1.98 60ft times and he is lowered also
x2 on what Super73 stated.
3r!c84 12-07-2010 03:00 PM
Re: need traction
It seemed like it hooked up a litte better with my 235/75/15 rims an tires on the back. Besides the 17s
Super73 12-09-2010 02:44 AM
Re: need traction
Launching like the pic of my truck requires starting to buy the parts on the list I provided.
