-   The 99-06 GMT800 Chevy and GMC Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=58)
-   -   '99 2wd Tahoe - rear grease seals (https://67-72chevytrucks.com/vboard/showthread.php?t=434467)
COBALT 12-06-2010 11:41 PM
Do I have to remove the axles to get to the seals from the flange ends or do I have to drop the cover and undo them from the carrier in the differential?
Also, I'm wondering what the spindle nut size is on the front rotors for getting to the wheel bearings. 30mm or 36mm?
truckdude239 12-07-2010 05:30 AM
Re: '99 2wd Tahoe - rear grease seals
yes axles have to come out to replace teh seals pull the cover and remove the clips and axles slide out
COBALT 12-07-2010 05:00 PM
Thought so - I'll probably skip doing this for now since I'm not seeing any signs of oil leak. I don't want to drop the pan right now...
clinebarger 12-07-2010 06:40 PM
The front axle nuts take a 36mm socket.
COBALT 12-08-2010 01:24 PM
Wonderful - thanks. Since we're down to one vehicle now it would be nice to know in advance what to expect when I go to pack the bearings.
