-   -   shaved cowl (https://67-72chevytrucks.com/vboard/showthread.php?t=434641)
justincat 12-07-2010 11:30 PM
shaved cowl
I was thinking about smoothing out my cowl. I was just wondering if anyone sells them already shaved?
VA72C10 12-07-2010 11:57 PM
Re: shaved cowl
I believe scotts hot rods on here sells them for around 800-850.
LockDoc 12-08-2010 12:15 AM
Re: shaved cowl
My friend Ron and I do these when we don't have anything else to do, so we won't be churning them out any time soon. If we can't get $300 + shipping we can't afford to do them as they take a lot of time to do, and do right.
This is an informational thread that justincat started, so please don't turn it into a "for sale" thread and get it locked... Thanks.
Here is a thread on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=366456
LockDoc
justincat 12-08-2010 12:16 AM
Re: shaved cowl
ok thanks. I might have to go on and do it myself. I think i need to shave and sell. lol. thanks for your reply!
VA72C10 12-08-2010 12:38 AM
Re: shaved cowl
if you do it yourself make sure to have it bolted down or it will curl up due to the heat and removing the center metal. Also tack and move to not let it heat up. take your time welding and also with the grinding.
Mondo 12-08-2010 02:05 AM
Re: shaved cowl
I like mine.. and a lot cheaper
http://67-72chevytrucks.com/vboard/s...d.php?t=285563
TomBennett 12-08-2010 11:36 AM
Re: shaved cowl
Question? I am thinking about shaving a cowl for my 67'. It just has the factory heater, no AC. Am I going to have problems with the heat in the winter?
LockDoc 12-08-2010 12:36 PM
Re: shaved cowl
As far as I'm concerned it won't be a problem. It will draw enough air "around" the cowl panel to provide sufficient air movement...
LockDoc
Fitz 12-08-2010 06:03 PM
Re: shaved cowl
2 Attachment(s)
Here's the before and after on mine. No need to look for prefab panels. Some cardboard, a sharpie, $25.00 worth of 18 ga cold rolled and two days of cutting and welding. Notice I didn't include bondo on the list...there isn't any!
The Big Green 12-08-2010 06:14 PM
Re: shaved cowl
Mines shaved, no wipers either!
