-   -   OEM side window glass? (https://67-72chevytrucks.com/vboard/showthread.php?t=437884)
Tom Vogel 12-30-2010 12:27 AM
Anyone know where I can get a set? The repop set I have look great but do not match the same dimensions as the originals.:waah:
CG 12-30-2010 01:39 AM
Re: OEM side window glass?
Are you talking blazer glass? Are they the same as truck glass?
JimKshortstep4x4 12-30-2010 06:29 AM
Truck and Blazer door glass are the same.
Jim
cdowns 12-30-2010 07:59 AM
try going to local glass shop with your originals and see if they will cut you a set to match
Tom Vogel 12-30-2010 09:50 AM
OEM glass is tempered, which is to say it is heat treated after it has been cut. That takes very special equipment. Flat glass cut in a shop would be lamented, or safety glass... Not the same. I may end up that way, but I would just as soon not.
Hawker7 12-30-2010 09:56 AM
I got my glass from Mikes Bump and Grind garage and it fit perfect on my 72. Might want to give them a try. Good prices and excellent to deal with.
haysonj 12-30-2010 11:16 AM
I have two you can have if you come get them. The only problem is one seems to be tinted a light greenish color so it may not be stock. Both were removed from a 69 parts truck.
Tom Vogel 12-30-2010 02:12 PM
Thanks,but what I need is NOS. My Jimmy is undergoing a full frame off.
Classic Heartbeat 12-30-2010 03:54 PM
Call me Tom!! I have located 7 NOS pieces. I will give you some phone numbers to call. By the way the Blazer windows have a differen't part number than the trucks do. I don't know why other than they might be a little thicker. All I could find is truck glass. WES
