-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Drum brake wheel cylinder question (https://67-72chevytrucks.com/vboard/showthread.php?t=443147)
VOLZ1207 01-27-2011 03:50 PM
I have a wheel cylinder leaking that i will be replacing. My question is will i be able to reuse my brake pads after i clean them up? They were soaked in brake fluid when i took the drum off. Any suggestions? Thanks
fattyarbuckle 01-27-2011 04:27 PM
Re: Drum brake wheel cylinder question
I have heard that brake fluid won't hurt the pads but i'm not sure I'd trust them.
The ONLY right thing to do is replace them They are not expensive (relatively) and even cheapo shoes will be better than oil soaked ones you have IMO
cparman 01-27-2011 08:52 PM
Replace the shoes. You will think you have them cleaned up, but the brake fluid will absorb into the shoes, and can cause the brakes to grab when applied, no matter how good the shoes look.
lolife99 01-28-2011 12:01 AM
x3
Replace the shoes.
If you are replacing a rear wheel cylinder, learn something from a mistake I made.
I had one wheel cylinder fail.
So I replaced the drum brake shoes on both sides, since they come in pairs.
Put everything back together.
Back on the road, right?
Not exactly.
With the replaced wheel cylinder now holding brake pressure,... it forced the opposite wheel cylinder to fail next.
(soaking my "newly installed" brake shoes with brake fluid)
Back to the auto parts store for more brake shoes.
So now when I replace wheel cylinders,... I do both sides.
VOLZ1207 01-28-2011 10:41 AM
Alright will do. Thanks for the info and advise. Take care
Shane 01-28-2011 11:05 AM
lolife gave the best advice ... replace both cylinders (they're cheap) and brake shoes ...
