-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   upper control arm rubber stop (https://67-72chevytrucks.com/vboard/showthread.php?t=451555)
daved 03-07-2011 02:14 PM
I am running slam specialties ss7 bags.....do i need to remove the rubber stop under the upper control arm??? have not air up yet but do these stop the travel?
Tmend 03-07-2011 02:35 PM
Re: upper control arm rubber stop
I'm not running a top bump stop don't thinks it will go up that high.
tubbedII 03-09-2011 01:17 PM
I pulled mine out, but I'm running DOM 2600's. At full lift the upper ca hits the spring pocket.
SCOTI 03-09-2011 09:19 PM
The rubber stop under the upper control arm limits droop when the suspension is extended (truck is jacked up to the point the tires are no longer touching the ground). Leave them in as they don't inhibit compression & do limit extension.
