-   -   Interesting Tag (https://67-72chevytrucks.com/vboard/showthread.php?t=456464)
gcburdic 03-31-2011 09:56 AM
Interesting Tag
I'm sure others have seen this too, but I was cleaning up the spindles for the 71 super project and found this metal band/ tag on the driver side spindle...I've looked up the part number on the tag, but haven't found anything.....any thoughts/ input??
BD 3986231
http://i973.photobucket.com/albums/a...r/IMG_5310.jpg
gcburdic 03-31-2011 04:11 PM
Re: Interesting Tag
anybody got thoughts or ever seen this...or is this like a rare corvette option:D
Rodk65 03-31-2011 04:21 PM
Re: Interesting Tag
After 20 years of driving trucks I have seen thousands of these. It is a seal used to seal the doors on a trailer or shipping container. The number on the seal was put on your bill of lading to verify that the load was not tampered with. They are made of plastic now but they used to be metal. It looks like it has been cut when it was removed. Not sure how it would end up in your truck.
gcburdic 03-31-2011 04:35 PM
Re: Interesting Tag
Thanks for the input Rod.....Yeah...I cut it off of the spindle....maybe that was a bad idea???....Wondering if the spindle was changed out long ago and they left this seal on it when it was installed....sure looks like a GM part # to me though??
4X4GMC1972 03-31-2011 04:37 PM
Re: Interesting Tag
I'm sure it was for identification purposes on the assembly line or the supplier to GM. Very common.
Shane 03-31-2011 04:38 PM
Re: Interesting Tag
cut one off my '70 back when I installed the ECE drop spindles ... still got it somewhere
KEL 03-31-2011 04:45 PM
Re: Interesting Tag
Mine start with "D & L"
One is 3985127
The other is 3985490
They were both attached to the seat frame of my 72 GMC
gcburdic 04-01-2011 10:22 AM
Re: Interesting Tag
Dang...thought I had a rare item:lol:....Thanks for everyone's input!!!
Piece of Work 04-01-2011 10:26 AM
Re: Interesting Tag
For you it's rare... you only have one!:lol:
Keith Seymore 04-01-2011 10:38 AM
Re: Interesting Tag
I agree.
It is the assembly plant "broadcast code", to help the line side operator choose the correct part.
There would be a different two letter (or three letter) code associated with each different part number permutation: so 2wd 1/2 ton would get one, 2wd 3/4 ton a different one, different one for 4wd, etc.
That way the operator needs only to walk over to the rack and select a "BD", rather than trying to remember part number 3986231 (vs trying to remember 3986232, 33, etc.).
They could be attached using the small bands you see here, or could be a paper tag stuck on the lug nut or an adhesive sticker stuck in some conspicuous place. You may even see paper tags wrapped on a part, like an ebrake cable or coil spring.
Hope that helps -
K
faribran 04-01-2011 10:42 AM
Re: Interesting Tag
Keith.. you are the man.
gcburdic 04-01-2011 10:49 AM
Re: Interesting Tag
:haha: Thanks Mark....I like your optimistic thought!!!:metal:
Hope that helps -
K
Wow....that helps explain it....Thankas for your input Keith!!!
:agree:
68Stepbed 04-01-2011 11:26 AM
Re: Interesting Tag
Cut one off the stock 72 spindles when I converted my 68 to 5 lug a few years back.
Mistercates 09-05-2015 02:48 AM
Re: Interesting Tag
I have this exact tag on the upper control arm of my 86 crossmember that I put under my 66 c10. I too was thinking it may be a part number. Wonder if its an inspection tag?
Keith Seymore 09-05-2015 09:58 AM
Re: Interesting Tag
Did you read my post (#10)?
K
