-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Dropmember Gas Tanks (https://67-72chevytrucks.com/vboard/showthread.php?t=458576)
54Caddy 04-11-2011 12:28 AM
Planing on getting a front drop member, I was wondering what tanks are you guys running in the rear. I want to try and find a tank that will still fit under the stock bed floor but give me enough clearance when layed out. This will be for my 79 so any one with square body please reply back.
broey 04-11-2011 01:23 AM
Re: Dropmember Gas Tanks
A lot of dudes are using a blazer tank between the frame rails. However I had my saddle tanks sectioned 3 inches so that I could keep both my fuel doors functional. I think it looks silly to have fuel doors that don't work. But pretty much any tank that sits higher than the lowest part of your frame (under the cab) should work.
Dinos63 04-11-2011 01:35 AM
YEAH THEY WORK OUT SLICK TOO KIND OF WISH I THOUGHT OF THAT ON MINE :lol:
54Caddy 04-11-2011 02:35 AM
my truck only has one saddle tank. sectioning it would proably make it like a 10 gallon tank to little for me. But that is one good idea. I will land up shaving the gas tank doors. pictures of your set up dino?
JNJchev77 04-11-2011 11:42 AM
Anyone have a pic of the blazer tank setup? For the Bagged/DM guys, how far from the ground does it sit when laid out?
54Caddy 04-11-2011 04:15 PM
Man not many pictures of tanks. Maybe its because alot of the trucks are still being built
SCOTI 04-11-2011 04:19 PM
I'm using a blazer tank for my 64 but it's not in the stock position. It's been raised several inches.
JNJchev77 04-11-2011 05:06 PM
What year blazer tanks are you guys using?.... Not the 73-91 right?
SCOTI 04-11-2011 06:06 PM
Mine is the 67-72 variety which is smaller dimensionally vs. the 73-87 blazer/burb tanks (20-ish gals vs. more).
JNJchev77 04-11-2011 06:40 PM
Thanks Scoti, You wouldn't happen to have any pics of your set up? It mounts under the bed floor? Just tryin to get an idea and best option for my set up... This is the next step for my build
SCOTI 04-11-2011 08:50 PM
It mounts under a raised bed floor. I could have done the traditional mounting but the tank would have been too close to the road for my taste. I'll see if I have any pics on the camera tonight.
robnolimit 04-12-2011 03:56 PM
Check the next issue of StreetTrucks, there is an article on custom tanks for 'dropmember' style builds.
JNJchev77 04-12-2011 04:38 PM
54Caddy... Man I just realized I kinda jacked your thread, my apologies!!! I was ready to post the same question, and there it was lol.
54Caddy 04-12-2011 11:46 PM
Its alll good man no worries were all just looking for answers. Seems not many square bodys with dropmembers on here. Next issue how you know Rob, you get the black and white issues or what ahahahaha
