choke connection help needed
I have a electric choke on my 350 chevymotor but have no wires to connect to the 2 terminals 1 aflat spade the other a female my question where do I get the wires from its a edelbrock carb. thank you.
Re: choke connection help needed
All you need is a short piece of wire to go to ground for the one terminal and the other terminal goes to battery power (when key is on only)
Solderless terminals are available at any auto parts store. |
You can use a wire off the wiper motor. Use a test light and find the one that has power when the key is turned on (yellow is a good if you see it on there).
