-   The 99-06 GMT800 Chevy and GMC Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=58)
-   -   Switching 6 cd changer to single (https://67-72chevytrucks.com/vboard/showthread.php?t=464114)
Eyegore 05-12-2011 03:31 PM
Is there a code that has to be used? The single is out of a 2004 hd that my son had but he said that there was a code to make it work.
Any help would be appreciated.
usmcchevy 05-16-2011 09:10 PM
Re: Switching 6 cd changer to single
Are you talking about the theft protection code? That is set by the owner, if you don't have it, the dealer is the only way around it that I know of.
BP68 05-16-2011 11:01 PM
I am a Gm tech that does a lot of radios. In 2003 the most gm radios are programmed on the data line. You will need to visit a dealer and have that radio programmed to the vehicle. They will just need to tell the truck it now has a U1C radio (single disc) instead of the UC6 (6 disc)
I did the opposite in my 06 truck. I swapped the single for a 6 disc.
Hope this helps.
Eyegore 05-19-2011 12:14 PM
Thank you for the inf. I hope the 6 cd works for you, mine keeps jambing up.
