Bolting a 700R4 to a Carbed LQ9...................
What do I need to bolt a 700R4 to a Carbed 2004 LQ9 6.0L??
I have the spacer and longer bolts for the flexplate already. I have the flexplate for the 6.0L also. Do I need anything else?? Thanks in advance. |
Re: Bolting a 700R4 to a Carbed LQ9...................
that should be it...plus a tv cable, and carb geometry correcter plate. I got mine from TCI but there are plenty of other options.
Any pics??
of?
check my build thread in my sig....lots of pics there. |
Is it going to be a big deal that I had to slot the holes in the 6.0L flexplate to fit the 700R4 converter?
I had to...no problems here and my flexplate is on its 2nd convertor. The torque converter has a nose that fits into the spacer and keeps it centered. You're just extending the holes to make them ovals instead of circles. As long as your careful making the holes fit...should be fine. My motor should be 500+hp....and it doesn't seem to cause any vibration that goes up and down with the rpms....and hasn't hurt anything, yet. :lol:
http://i15.photobucket.com/albums/a3...9/IMG_2894.jpg
http://i15.photobucket.com/albums/a3...9/IMG_2893.jpg Well here it is. Any guess what color I want to paint the 65 carryall?? |
Does anybody know which oil line in the 2nd pics goes into the "IN" port on the dual oil filter housing??
Pulling this out to install the 6.0L http://i15.photobucket.com/albums/a3...9/IMG_2863.jpg http://i15.photobucket.com/albums/a3...9/IMG_2860.jpg |
do you need the dry sump system? or is it more of well its already there?
...and what happens to the blown bbc? |
They both are nice motors. Looks like a good bit of hp will be lost. Are you going to supercharge the new motor? That would be sick! They sell maniflods to bolt that blower on to the new motor....
Had all this junk sitting around collecting dust and I am pulling the motor to put into my prostreet 68 shortbox any ways soooo putting in this Carbed 04 LQ9 with the ZO6 cam/700R4. Want the carry-all as more of a driver than a hot rod. |
