-   -   Wipers have a mind of there own?? (https://67-72chevytrucks.com/vboard/showthread.php?t=46516)
CRRoy71 03-29-2003 05:32 AM
Every time I turn on my ignition, my wipers cycle a few times like I have hit the squirters. You know how if you just tap the windshield wiper squirt button, your wipers cycle a few times.
This is everytime I turn on the ignition :confused:
The previous owner said there may be a short in the wiper switch? I have bought a new wiper, cruise, turn signal lever, but I just wanted to run this by the group before I tear into my steering column.
Prerunner1982 03-29-2003 05:59 AM
this seems to be a regular accurance on our trucks... my truck use to keep going after you turned them off.. replaced the switch.. not they will cycle about ever 12 min while driving contiuously..sometimes...rarely its hard to make it stop... a bad ground i believe.. but never taken the time to look into it.. its funny to see peoples faces when my wipes just start going and my hands done move.. they think my truck has a Demon! LMAO
old Rusty C10 03-29-2003 10:28 AM
it happened on my truck and it was definately the wiper switch i replaced it and no more problem hell the ford ranger even had a recall about that several years ago
LOHRTBT 03-29-2003 10:30 AM
Welcome to the club!! lol
CRRoy71 03-29-2003 12:48 PM
Faulty wiper club
Hello, my name is Chris.................and I have faulty wipers
(group says........hello Chris) :whine:
DRASTiK 03-29-2003 01:46 PM
can I join in too? I just replaced my switch and lever, and still have NO wipers at all. I replaced the switch mainly because my turn signals didn't work correctly and my lever was broken. Unfortunately this didn't fix my problem of no wipers.
Dave
CRRoy71 03-29-2003 05:12 PM
Man!, What do you do when it rains?:(
Hope you have other means of trans.
low 84 03-29-2003 08:38 PM
i'm in the club too. mine will run for 10 min and then shut off and not come back on unless the truck sits for an hour. wipers suck!
swervin ervin 03-29-2003 10:13 PM
Sounds like some of you have bad motors to me, especially Ryan.
CRRoy71 03-29-2003 11:02 PM
My wipers work great when I want them to, the problem is they also work when I don't want them to :p
apstguy 03-29-2003 11:21 PM
Hey! Welcome to the club! From what I have come up with it is one of two things: the delay control module is fried or the windshield washer pump is dead (if you unplug it, it causes more problems). I'm going to replace both. I'm tired of my windshield being streaky!!!!!
Marks 85 03-30-2003 10:28 AM
Yup Im a Member of the BWC too, THey come on 4 times when I turn on the key then turn off. O well at least they work!
CRRoy71 03-30-2003 02:36 PM
That sounds exactly like mine, any idea what's causing it?
By the way, where is Benbrook?
racedvl 03-30-2003 03:06 PM
Mine cycle once if I put it in low 1. :confused: That's in the burb though.
DRASTiK 03-30-2003 03:09 PM
well luckily here in Yuma, it doesn't rain much at all. But I'm going to have to see if the motor is getting power or not when the switch is turned on, and then go from there. Personally I think that the new arm I just installed isn't the correct one. Hopefully I'll figure it out soon.
the baron 03-30-2003 03:32 PM
Welcome to the club...
Got the same problem.
Wipers work whenever I don't want them to work !
The "pipi" pump does not work either...
:o Thought of changing the switch , resolved the problem for now , pulling out the connection , till it rains again.
Just getting a little wet sometimes...
79 C10 LWB
77 Impala 250ci
"Efficiency & precision,
contact the Baron..."
pkbinplano 03-30-2003 09:55 PM
Its the module under the steering column. Little black box with
silver fins. My delays did same thing. (actually no delay)Bought a used delay module off ebay. Delays work but I can toot my horn and my wipers cycle. LOL
gchemist 03-31-2003 01:35 AM
Mine seem have a mind of their own too. :eek:
