-   Engine & Drivetrain (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=24)
-   -   Couple Questions (https://67-72chevytrucks.com/vboard/showthread.php?t=466651)
thirdstreettito 05-27-2011 03:49 PM
Couple Questions
1. On my 88 TBI, what pros and cons are there to replacing rocker arms? Pros and cons to each type(roller tip etc)?
2. What's the best valve cover gasket to use with aluminum valve covers on cast iron heads?
3. Is my stock (http://www.slosh.com/ck5/tankiebuild...-ducting-2.JPG) intake better than my open element(http://img.photobucket.com/albums/v2...r/IMG_5667.jpg) intake?
4. What heads could increase my MPG's?
Thanks, Bradley
GASoline71 05-27-2011 05:32 PM
Re: Couple Questions
No heads are gonna increase MPG.
Unless you have a hopped up rod. Stock rockers or roller tips are just fine.
Gary
thirdstreettito 05-27-2011 07:08 PM
Gary
Whats the difference? Performance? Sound? Anything at all or just a waste of money?
Sillyoldman 05-27-2011 07:27 PM
No difference. I would not worry about it unless you are swapping cams.
thirdstreettito 05-30-2011 03:58 PM
Bump
thirdstreettito 05-31-2011 04:45 PM
Bump ttt
thirdstreettito 06-04-2011 12:56 AM
Bump
