-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Calling Suspension Guru's (https://67-72chevytrucks.com/vboard/showthread.php?t=472070)
texastrendz 06-28-2011 10:04 PM
I need (in plain English) how shock angles effect the rear suspension. I am running a trailing arm setup with bags in front of the axle. I need to lay the shock over some because of the length. I was wondering what the best operating angle will be of the shock. I measured about 60 degrees off of 90. Is this to much angle for a kyb series shock? Any and all help would be great.
Clyde65 06-29-2011 10:07 AM
Re: Calling Suspension Guru's
shock re-locators!
ECE/CPP/POL all have front and rear Re-locators for our trucks that will make the shocks sit right when lowered.
How low is your truck? springs or bags?
texastrendz 06-29-2011 11:33 AM
Originally Posted by Clyde65 (Post 4762275)
shock re-locators!
Sorry it is not a stock application. I really just wanted to know at what angle do the shocks start loosing function. From what I have read as long as I stay ahead of 45 degrees I should be fine. I just wanted to make sure before i start cutting up my poeder coated frame. Any and all help is appreciated.
Clyde65 06-29-2011 12:31 PM
I have read, the close to 90 the better but since I am not an expert, I will bow out and wait for an expert.
texastrendz 06-29-2011 12:39 PM
No reason to bow out, i like hearing any and all opinions.
texastrendz 06-29-2011 12:40 PM
I did find a pretty cool website:
http://www.4x4review.com/Features/Te...7/Default.aspx
SCOTI 06-29-2011 04:52 PM
I remember reading somewhere to limit the angle to 35deg from 90/plumb. Not sure how 'quickly' from there the leverage diminishes though. Hopefully, someone will chime in w/some text to correctly educate us....
PBFAB.COM 06-29-2011 05:16 PM
There's a lot of variables that go into this, and a lengthy explaination...but as a rule of thumb try and keep the shocks between 20 and 30 degrees and you will be fine. :)
Nate
craig@ridetech.com 06-29-2011 05:26 PM
The link above does give a lot of great information, but to dumb it down the best I can.
Mounting the shocks vertical and as far out to the wheels is the most ideal set up. Most of the time you see them angled in, this allows you to use a shorter travel shock but still have plenty of or more axle movement. Here at Ridetech we don't like to go more than 30 degrees over. As soon as you start to lay them over at an angle the effectiveness diminishes, the farther over, the more it diminishes. The adjustable shocks have an obvious advantage here over a fixed valve shock, but it all comes down to each application and what will work best for your situation and driving style.
texastrendz 06-29-2011 05:28 PM
Nate
Thank you sir
texastrendz 06-29-2011 05:29 PM
Thank you sir.
