-   -   230 to 350 swap pics please!! (https://67-72chevytrucks.com/vboard/showthread.php?t=473869)
JasonWynn88 07-10-2011 10:55 AM
Doin a engine swap in my 65 c10 from a 230 6 cylinder to a 350 with 3 speed would like to see some pics of the conversion THANKS
Turkey 07-10-2011 10:59 AM
Re: 230 to 350 swap pics please!!
Jason, I'm about to do the same thing. What tranny are you going to use?
JasonWynn88 07-10-2011 11:09 AM
I using the stock 3 speed manual. Needed some info on this swap i know it pretty simple and popular in these trucks.
Captainfab 07-11-2011 12:51 AM
Is there something specific you need to see?
WTexChevy 07-11-2011 11:17 AM
http://i4.photobucket.com/albums/y12...e/CIMG0104.jpg
WTexChevy 07-11-2011 03:46 PM
I used the stock 3spd. Used the flywheel/clutch/starter/mounts of the 230. Only thing I needed to buy for the swap was a Z-Bar pivot ball from NAPA. (make sure you have a pilot bushing in the V8 crankshaft) I did use an internal regulator alternator but I think you could use the one off the 6 if you extend the harness and have the correct brackets. Stock throttle linkage will need to be extended. I welded in a piece of allthread but couldn't get WOT so I switched to a cable throttle. Stock lower hose will work if you cut it. You'll need to run a 12v wire if you use an HEI distributor. Swap took a better part of a saturday but that was with me cleaning and throwing some paint on the firewall/inner fenders.
kieth 07-11-2011 04:35 PM
I have never done the 3 spd swap but I know you have to have some mounting points on your engine block for the linkage ? ask Capt fab about that ??
WTexChevy 07-11-2011 04:55 PM
the stock 6cyl. Z-bar (bellcrank) will work you just need the pivot ball. The pivot screws into a threaded boss in the block.
kieth 07-11-2011 05:19 PM
I was not sure what it took when I put my 350 in so I just woosed out and put a 700r4 in so I would have overdrive , 3:73, 29" tire height , looking for 1900rpm and 70mph----I got it... and i did not need the pivot ball. Kieth
WTexChevy 07-11-2011 06:25 PM
Pivot ball...
http://www.kdkclassic.com/UserData/I...rge/102905.jpg
