-   -   Overflow tank? (https://67-72chevytrucks.com/vboard/showthread.php?t=476075)
gotchamel 07-23-2011 08:24 PM
Overflow tank?
Where is the correct location for a coolant recovery tank on a 69 c10{if it had 1?}.Got a aftermarket 1 but does not seem to really fit anywhere practical.
Shyguy 07-23-2011 08:28 PM
Re: Overflow tank?
Didn't have one from the factory. Some people put them on the radiator core support and others put them on the opposite fender from the window washer bottle.
fastwillie 696969 07-23-2011 10:07 PM
Re: Overflow tank?
i just bought one from jegs with the bracket im going to mount mine where the battery used to be
elf w/capital T 07-24-2011 12:21 AM
Re: Overflow tank?
i may be wrong but ....front portion of the passenger wheel well 'tub'... sits right behind the battery...
Lippyp 07-24-2011 03:07 AM
Re: Overflow tank?
Some pictures of peoples would be good as I've just bought one from summit racing and haven't got a clue where to mount it, the current bottle (old coolant bottle!) is tucked in the passenger fender
dubds10 07-24-2011 03:32 AM
Re: Overflow tank?
Various on the truck but it's an option from what I've seen. Not mandatory on any of them. Typically it bolts to either the driver's front fender or passenger side front area. Just after the battery beside the wheel well. I've found them on both sides from the factory.
Steve Hafner 07-24-2011 04:23 AM
Re: Overflow tank?
5 Attachment(s)
It would be a lot easier to have it near the cap, on the passenger's side, so you wouldn't have to run the hose across the top of the radiator.
Here are a few that I've saved:
dmack91 07-24-2011 06:43 AM
Re: Overflow tank?
I got a universal one from NAPA and it fit between the battery and the pass. fender (just barely).
71blksuper4x4 07-24-2011 09:21 AM
Re: Overflow tank?
The optional/dealer installed tank, was typically mounted to the radiator support on the driver's side, just about where a second battery tray would mount. Trevor
Longhorn Man 07-24-2011 11:40 AM
Re: Overflow tank?
i've only seen proof of one factory one, and it was a gov truck. All the rest were dealer installed, or more likely, parts store stuff. You can still find them that look much like the dealer parts pieces.
68gmsee 07-24-2011 12:26 PM
Re: Overflow tank?
2 Attachment(s)
Two options on my GMC. The second pic is what I have right now. Spent $10 at Lowes on it.
Lippyp 07-24-2011 12:36 PM
Re: Overflow tank?
I was wondering if anyone had put theres the front side of the core support as I was thinking about mounting mine there, Looks like a goer, mines a black Summit 1 quart job so won't be too obvious from the grille.
71 super 07-24-2011 06:50 PM
Re: Overflow tank?
5 Attachment(s)
Here is a picture of the dealer installed GM tank. It is identical to the version Andy mentioned on the government truck. I bought this one several years ago it was NOS sealed in the GM box. It mounts on the core support just above the horn as trevor stated in about the same location as the aux. battery tray. I also included some pictures of the truck just because :)
chewychevy67 07-24-2011 07:26 PM
Re: Overflow tank?
I to have a nos set up and the instruction sheet shows it goes right where 71 super has his.
dukcaln 07-24-2011 07:30 PM
Re: Overflow tank?
I find myself in need of one too, didn't have one when i bought the truck..... so you can purchase one from napa over the counter?
my67c20 07-24-2011 09:20 PM
Re: Overflow tank?
2 Attachment(s)
Bought one from summit. Saw another post that someone used a metal water bottle, another that they used one of the new aluminum beer pints with the screw on lid. Here is some pictures of my installation. Mounted off the factory battery bracket.
dubds10 07-24-2011 10:56 PM
Re: Overflow tank?
I didn't know these were so rare lol Most my trucks have had one hahaha
71 super 07-25-2011 01:42 PM
Re: Overflow tank?
The GM version is pretty hard to find. The others pictured are parts store units and available almost every where. The GM unit is pretty big and has a dedicated bracket/holder to support on all sides as well as the bottom.
gotchamel 07-25-2011 02:17 PM
Re: Overflow tank?
The one I bought is from LMC,it will not fit on the overflow side of the radiator.It will have to go on the drivers side and route hose.It seems rather oversize?
original-71 07-25-2011 05:17 PM
Re: Overflow tank?
71 super thats one beautiful truck, can i see more pics of that overflow? and where did you buy it from if you dont mind me asking? i want something close to stock also.
dubds10 07-25-2011 09:43 PM
Re: Overflow tank?
I got a few of the GM ones so they aren't rare to me :metal: Never seen any other kind on any of the trucks I've bought. And to think I was just going to throw them out cause I figured everybody had one :lol:
71 super 07-25-2011 10:22 PM
Re: Overflow tank?
Original 71 I got the tank off of ebay a couple of years ago. Let me look back through some photos and see if I have more of the tank.
karl 10-30-2011 04:45 AM
Re: Overflow tank?
The one i was just overcharged for($28) by LMC is a pc of Taiwan crap. Only one of the holes lined up and the cap wont snap on. Even the plastic is paper thin unlike the originals. Supposed to be a factory replacement for my 75 C10. The last one i bought from Classic Ind. was better made. I think this is the last one i will buy. Next time i will make something. Poor quality products fall by the wayside.
Ironhorse 10-30-2011 09:37 AM
Re: Overflow tank?
Don't have a pic of it but I installed mine on the passenger side just aft of the battery. Used a w/s washer tank and bracket. Looks stock and matches the factory washer tank on the driver's side. Just don't get confused and put anti-freeze in the driver's side tank. :lol:
oldgold70c10 10-30-2011 12:33 PM
Re: Overflow tank?
I used a washer fluid bottle and mounted mine next to the battery. It works and looks stock to those who don't know.
