-   -   What transfer case do I have? (https://67-72chevytrucks.com/vboard/showthread.php?t=478116)
ky_kid 08-05-2011 02:40 AM
Can someone tell me how to identify my transfer case?
203, 205, 208... I know the differences between them but how can you tell them apart visually?
rcbildr 08-05-2011 02:49 AM
Re: What transfer case do I have?
The cases should have a tag on them. The 203 and 205 have a cast iron case and the 208 is aluminum.
motornut 08-05-2011 10:29 AM
2 Attachment(s)
88 208
Jonboy 08-05-2011 12:18 PM
The easiest way (to me) is the shift pattern, and case construction. Your truck most likely would have a 208 case. The shift pattern from top is 2hi, 4hi, N, 4 low. The shifter is mounted to the cab floor, instead of to the case itself.
bmchevy1979 08-05-2011 12:57 PM
2 Attachment(s)
pic#1 NP203
pic#2 NP205
ky_kid 08-05-2011 01:39 PM
Thanks guys... great info
Unions 04-30-2018 12:23 AM
What transfer case would come stock in my 1972 Chevrolet 1500 sb350
Indyfab 04-30-2018 11:01 PM
Should be a NP205
Killer Bee 04-30-2018 11:09 PM
found this recently while browsing the interwebs..
TRANSFER CASE SPOTTER’S GUIDE
posting pictures of yours will help too, good luck!
Unions 04-30-2018 11:17 PM
Np 205 is that the one with the chain but more importantly where can I find a how to manual to dropping the tranny and transfer case down safety
sweetk30 05-01-2018 07:11 AM
np205 = part time gear to gear
np203 = full time gear to gear range box and chain for the front output .
