-   -   frying your HEi coil and pickup (https://67-72chevytrucks.com/vboard/showthread.php?t=478748)
vtwinsport 08-08-2011 11:38 PM
hey all,
just a note to all who may be installing better guages. I unknowingly fried my coil and pickup in my MSD streetfire ignition by accidently (??) grounding the tach lead while connected to distributor and in the engine.
Must have happened when putting the guages in.
Result was erratic stalling, hard starting, a nervous tach needle that looked like a heart monitor (up and down spikes).
See this link if you need info- very bottom of page is note about avoiding this. Also good info for testing out you dizzy pieces.
http://www.angelfire.com/realm2/84ca...coil/coil2.htm
motornut 08-09-2011 12:30 PM
Re: frying your HEi coil and pickup
3 Attachment(s)
guess i'm lucky mine didn't fry when i hooked up mine
was shorted to the side
Goldfinger 08-09-2011 06:54 PM
did you not disconnect the battery?
motornut 08-09-2011 08:50 PM
me?mine was the tach signal
vtwinsport 08-09-2011 11:19 PM
just need to clarify that it was the cold and module under the rotor, not the pickup at the shaft of the rotor. see picture attached. flat black plastic piece between screws is module.
