700R4 Questions
First of all, is it worth the cost and effort to install a 700R4? I will have a TH400 but I was just wondering if the overdrive is worth it. Also, there a quite a few for sale around here but they are all advertised as 4x4 transmissions. I have a 2wd. Does it make a difference?
Posted via Mobile Device |
Re: 700R4 Questions
Yes, it makes a difference. You will need a 2wd trans. Upgrading the transmission is only one element to this O/D equation. More than likely you will need to rebuild or replace your rear end so that it has proper gearing for an overdrive transmission. I am undergoing this mod right now, and it is expensive. $1000 for the rear rebuild, and $1500 for the 700r4 rebuild and install. Not to mention you have to get a driveshaft because your TH400 has a yoke and the 700r4 doesn't.
In the end, overdrive + proper rear gearing makes for a more modern / efficient vehicle, but it comes with a price tag. Like I said, I'm going through this process right now, and I cannot wait to see and feel the end results. |
Re: 700R4 Questions
Re: 700R4 Questions
I dumped a TH350 and fulltime transfer case for a 700r4 and NP241 and went from 6-8mpg's to 10-12mpg's... Not a bad investment if you plan on owning the truck for a long time.
*EDIT* - this is all with 4.56's on 35 inch mud terrains... a 2wd will probably show much better gains. |
Re: 700R4 Questions
Re: 700R4 Questions
visit vintageair.com... They've got some A/C solutions for you.
Re: 700R4 Questions
Money is key! haha, I was able to get a donor Suburban for 1,000 with a blown motor, so the transfer case, transmission and fuel injection all made a one way flight to my truck.
