Pin Removal on Bulkhead ?
So Im replacing all the bad and corroded wires I can find and Im down to the ones in the engine bay. The male connectors though I cant seem to remove. It looks like there is a small slot on both sides of the connector, Ive tried using a straight dental pick, a T shaped pin but cant seem to release it. It looks like the pin should have a tab on one side of it that you can push in and then pull it out. However, its just not working for me today. Any help?
Re: Pin Removal on Bulkhead ?
Never mind. Did a search in here and found out how.........
Can you share what you found out?
I used needle nose pliers and squeezed the terminal gently and it pulled right out
Thanks.
