-   The 1969 - 1972 Blazers and Jimmys Message Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=36)
-   -   Gas Tank ? (https://67-72chevytrucks.com/vboard/showthread.php?t=483802)
yellow70 09-10-2011 07:06 PM
Gas Tank ?
Is a blazer and burb gas tank the same ? and can i use a burb tank on my blazer with out any problem?:smoke:
70cst 09-18-2011 04:11 PM
Re: Gas Tank ?
My guess is yes but I'll let others jump in ...
ntd 09-18-2011 08:48 PM
Re: Gas Tank ?
how many gallons and from what year is the burban tank from
Steven B 09-19-2011 10:44 AM
Re: Gas Tank ?
The tanks are the same except for the neck. The burb neck is shorter. You should be able to use the burb tank with a longer rubber hose.
yellow70 09-19-2011 05:45 PM
Re: Gas Tank ?
thanks!!!
69-72 09-19-2011 07:42 PM
Re: Gas Tank ?
Or you could unsolder the neck from the Blazer tank and put it on the Burb Tank. Gas hose is $$$$
