-   -   Factory Antenna cable (https://67-72chevytrucks.com/vboard/showthread.php?t=484814)
jac70ss 09-17-2011 04:32 PM
Can someone please show or tell me how the factory routed the antenna cable on a 66? I removed mine and was trying to reinstall but, believe it or not, I can't find the hole in the cowl. It's not on the right side near the extension, not sure where it is. Any help will be appreciated
db65 09-17-2011 05:49 PM
Re: Factory Antenna cable
my 65 is pas side, slightly behind the fresh air vent and just above it. With the fenders/cowl piece off it's on the seam between the cowl/air vent. Hope that makes sense. I can get a picture if needed.
markeb01 09-17-2011 07:43 PM
Here’s the factory diagram for a 1960 installation. Not sure how much (if any) it may have changed by 1966:
http://img5.imageshack.us/img5/5519/...ssories089.jpg
http://img233.imageshack.us/img233/6...ssories090.jpg
jac70ss 09-17-2011 08:03 PM
My factory antenna looks a little different. The routing of the antenna in the diagram makes perfect sense, however, my truck doesn't have a hole there. It is a factory radio cab, I just didn't pay attention when I pulled the cable out. DB65, a picture may help if you don't mind. Thanks for the help!
db65 09-18-2011 01:16 PM
Here's a picture of inside and out. The inside looks like a blob of silicon is around the hole but it's actually a rubber grommet. http://i.imgur.com/7yMKE.jpg
http://i.imgur.com/2kKMX.jpg
jac70ss 09-18-2011 02:13 PM
Thanks DB, my cab doesn't have a hole there but it's about to!
