-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   what is the proper direction of drilled and slotted rotors (https://67-72chevytrucks.com/vboard/showthread.php?t=488073)
funkytechmonkey 10-08-2011 09:01 PM
I've had different people tell me different ways. What's the right way?
lolife99 10-08-2011 10:40 PM
Re: what is the proper direction of drilled and slotted rotors
I've seen them both ways.
I'd like to know this also.
funkytechmonkey 10-08-2011 11:56 PM
My rear rotors from wilwood have an arrow on them pointing so the slots are going against the turn of the wheel. But I called Performance Online and they were telling me the slots should go with the turn of the wheel bc it will eat the breaks up faster.
oldspowered67C10 10-09-2011 12:21 AM
This is the correct way.http://67-72chevytrucks.com/vboard/s...d.php?t=484991
lolife99 10-09-2011 12:24 AM
Originally Posted by oldspowered67C10 (Post 4943137)
That's the way I personally think they look best.
Baer Brakes says to run the slots,... just opposite, of that.
Who knows.
Does it really matter?
funkytechmonkey 10-09-2011 03:28 AM
Thats what I am trying to find out... if it really matters
MADMIKE 10-09-2011 03:33 AM
IIRC so does Power Slot/STOP-TECH.
I cannot verify which way is the correct orientation of the slots cut into the rotor face. However, if the vanes inside the rotor are angled or curved, the angle should be sweeping back to pump air from the hat to the outer edge for proper cooling.
http://www.stoptech.com/tech_info/im...ed_cutaway.jpg
funkytechmonkey 10-09-2011 10:13 AM
Yea I have found documentation on them about the internal vanes and I can understand that. It's actuallly a functioning design of the breaks. Mine are straight.
