adding a tach dash: do i need anything besides the harness?
hey all, i have a 70 chev 350 v8 with HEI that I recently bought (havent installed yet) a restored tach dash for. just wondering if there is anything i need to buy to make the tach work when using the hei dist. thanks in advance for any knowledge you may have regarding this subject
Re: adding a tach dash: do i need anything besides the harness?
The tach should work fine. Try and find a factory clip connection for the harness to the distributor. Will make a clean connection and can't come loose.;):chevy:
that will be okay for a hei coil distributer?
