Hydro Boost Pics
Im looking for pics of Hydro Boost units for the 55-59 chevy trucks. I would like to keep it under the cab. Thanks in advance.
Re: Hydro Boost Pics
4 Attachment(s)
I moved mine under the bed. I made my bed tilt for easy access.
Kim |
Kim 57, that it really cool!!!!
Posted via Mobile Device |
That is a great design.
Kim |
Hey Kim:
I like that and saw it on your build. What is the down side if any? |
Kim |
I would be concerned with the push rod flexing to much or bending during a panic stop and the excess stress on the threaded connector at the end near the boost unit. Most all the long brake rods I have seen are pull type not push type.
Putting 2 heim joint along the rod would help a great deal with the flex. Putting one at the booster next to the connector and one mid way on the rod. |
The rod is 3/4" seamless. I doubt I will have the strength to flex it. If I do I will just step up to some 1" and that should cure any problem. Kim |
Kim where did you get the bracket for the pedal and is it a stock pedal?
DWCSR
Any ideas on how to make it a pull system? |
http://www.piratejack.net/index.php?...emart&Itemid=6 Kim |
Pivots 1 and 2 have the push rods attached at the top and the pull rod at the bottom and of course they have a center pivot. The pivot center is attached to the frame or a bracket that is very stable. It would take some fab work but solves the problem of the rod possibly bending under a panic stop situation. |
Have you ever done it and do you have pictures?
I haven't had a need to do a setup like that but I do have a Harley trike in the shop that uses a similar pull rod setup. I can snap a few pics and post them
Here is a few pictures of the rod setup on the Harley. Its really the same idea on any remote cylinder that 2 or more feet away.
http://www.thehollisterroadcompany.c...icar/Brakerod/ |
looks good kim, nice work
not very good pictures, but...
this is a 03 mustang hydroboost installed under floor using the stock swing arm and pedal. http://i306.photobucket.com/albums/n...c/IMG_0129.jpg http://i306.photobucket.com/albums/n...e/IMG_0275.jpg no hoses in this picture and i installed a remote reservoir on it. the mustang mc tank has the same fittings in the mc as the mercury villager minivan with remote reservoir. i pulled the tank off, inserted the adapter fittings and used the villager reservoir mounted on my firewall. this is the bracket i made to mount it. after i fabbed it up a made a 3/8'' boxing plate to weld to my frame with bolt holes tapped in it so i could unbolt the whole bracket if needed. http://i306.photobucket.com/albums/n...c/P1020029.jpg |
did you just use flat metal stock and a piece of angle iron on the bracket? thank you for the info on the remote reservoir. i was wondering how i was going to fill it once i installed it on the frame. i am using a hydroboost out of a 2003 suburban
the pic of the bracket is just tack welded, look at the first pic and you can see the gussets i added.
i used a piece of 4x4x3/8 angle with one leg cut mostly off for the bracket. i used a piece of 3/8 flat to weld on the frame with threaded holes to mount the bracket angle. |
thanks Ogre. i picked up my hydroboost i am going to try to build my bracket soon
Thanks Tri5 |
3 Attachment(s)
Here’s my set up, hydro boost from a suburban and the cover is off an older van
I put a 3/16 plate in the frame first then a made up another 3/16 plate to hold the booster The two arms that come out are ½ x 2 flat bar Then 3/16 gusset to tie it all together I built my booster mount in lots of pieces so I could have some adjustability when test fitting As for filling the reservoir or topping it up it should only be done every once in a while, any more then that I got bigger issues to deal with |
this is off an 03 cobra, the cobra had a bigger motor that interfered with the vacume booster used in the gt.
http://i306.photobucket.com/albums/n...c/IMG_0273.jpg from this side you can see how it bolts to the 3/8'' plate welded on the frame. http://i306.photobucket.com/albums/n...c/IMG_0272.jpg http://i306.photobucket.com/albums/n...c/IMG_0270.jpg i don't have any pics of the remote reservoir, the plastic tank pulls off the mc. there are rubber inserts that hold the tank in, these stay in the tank. http://i306.photobucket.com/albums/n...c/IMG_0274.jpg the mercury villager or nissan quest have a different mc but it has a remote reservoir and plastic inserts that go in the mustang mc. this website shows all the parts needed from the donor vehicle, any yr 98 to 02. 46090 is the tank, 46020n is the plastic insert needed to go into the mustang mc. i found 1/2'' teflon lined ss braided hose from a hydraulic hose supply house, it barely fit but it fit. the hose listed for $9/ft, the counterman was a car guy who new about our shop, he sold me 8 ft for $18. :D i'm sure there are other hoses that will work but my research showed that teflon was impervious to brake fluid. the factory five guys use the same mc and hydroboost and it is located way under the fender. i found the remote reservoir info in a factory five site. |
