-   The 1967-1972 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=8)
-   -   SC F/S NOS wheel studs (70-72) rear (https://67-72chevytrucks.com/vboard/showthread.php?t=498779)
PT'S 70 CST 12-16-2011 03:42 PM
I researched these and called my GM parts guy and it appears that these from the part # fit 70-72. The Dorman after market ones at Advance run over $20.00 each. I will sell all 6 of these for $60.00 shipped. You can refer to this WIW thread for more info on these. http://67-72chevytrucks.com/vboard/s...d.php?t=497411
PT :chevy:
lolife99 12-16-2011 03:53 PM
Re: F/S NOS wheel studs (70-72) rear
Are these 7/16" or 1/2"?
('70 was 6-lug 7/16", and 71-72 were 1/2"-20)
PT'S 70 CST 12-16-2011 04:04 PM
From what I was told in his computer it specifies 70 disc (which is 5 lug) and 71-72 all.
PT
STP67-72 12-16-2011 04:15 PM
Lolife is correct on the years.
PT'S 70 CST 12-16-2011 04:22 PM
They are indeed 1/2"-20. I just checked them on my Weld wheel lug nuts for my 70 CST 5 lug disc.
PT
lolife99 12-16-2011 06:38 PM
PT
Trucks were still drum brake in 1970.
Thanks for clearing up the size.
PT'S 70 CST 12-16-2011 06:48 PM
Some of your 70's were 5 lug disc especially some of your more highly optioned trucks. I have a 1970 CST three owner truck and it is an original 5 lug disc brake truck.
PT
lolife99 12-16-2011 07:00 PM
PT
Never ever seen a 5 lug disc brake truck in the 1970 model year.
mcbassin 12-16-2011 08:50 PM
This is news to me too. I have never seen or heard of a factory deivered 5 lug disc brake 70 model.
Good deal on the lug bolts. bump for ya.
PT'S 70 CST 12-16-2011 09:30 PM
I will see if I can get you guys some black and white info on this. I have seen several 70's with disc in this area. The info on these studs was given to me by one of my good friends that has been a GM parts manager for 30+ years and I would damn near trust anything he told me about a GM product. The info he gave me came straight out of a GM parts book.
PT
PT
PT'S 70 CST 12-17-2011 01:12 PM
Here is some information
I also have three other option sheets if you would like to see them also. This is some info that I had on my pc and if you want I will try and scan the parts book that he has showing correct applications for these studs.
PT
lolife99 12-17-2011 02:29 PM
Does your '70 have the J62 option code on the SPID?
If that document is correct,... then you could have had it on any of the 67-70 trucks?
Maybe we should start a separate thred for this.
I am very interested to say the least!
72ironmike 12-17-2011 02:57 PM
Keith is right. That would be neat to see it on a 67-70 spid. I've had many 67-70's and never run into it. Surely a member has seen it. Pretty cool. Learn something new every day !
Vintage Windmills 12-17-2011 02:59 PM
Notice that option list includes options for big trucks too, so maybe the discs were for a different application and not the light duty trucks? Hope it was an option that would be cool!
PT'S 70 CST 12-17-2011 06:09 PM
Someone painted over my spid when they painted the truck so unfortunately I cannot refer to it. This is a GM document so I do not see why it would not be correct. I will start a new thread when I get to work tonight and try and post the other three option sheets.
PT
OhOneWS6 12-17-2011 07:00 PM
Gotta be. Add me to the list to see how this turns out. It is well documented that 71 was the first year for 5 lug and disk brakes on the 1/2 tons. Any 70 or earlier 1/2 ton that is a 5 lug disk truck has been converted at some point.
PY. Do you have a picture of your control arms? I'd be curious to see if they are screw in or press on bushings on the shaft.
mcbassin 12-17-2011 07:09 PM
:smoke:Patiently waiting to see more on this. Please post a link to the new thread here.
Bump for ya.
PT'S 70 CST 12-17-2011 08:23 PM
Guys I will get to this as soon as I can but I am on 12 hour nights for the next three nights. I will try and start a new thread in the message board and post the link here. I will also try and get the copy of the GM parts manual from my buddy at the dealership where it states that these studs are for 70 disc and 71-72 all. I feel like I am at the firing range and ya'll are holding the guns but I can handle it.:help:
PT
too much stuff 12-17-2011 09:17 PM
I have also never seen factory disc brakes on a 70 pickup. The sheet pictured looks to be big truck or i wonder if elcamino shared the same options numbers?
Hopefully this will help clear things and not clutter your sale. The info from my parts book list these as rear hub with ho35, spicer 44 and 60-35 axle, ho 52, ho 72, sp 60 and h110 axle.
lolife99 12-17-2011 09:23 PM
Look at the transmissions listed on that list.
Were all of those available in 1970?
PT'S 70 CST 12-18-2011 06:08 AM
Here is a link to the new thread that I started.
http://67-72chevytrucks.com/vboard/s...65#post5070665
PT
71 super 12-18-2011 11:12 AM
PT look at the spindle arm where the drag link attaches. There should be an aluminum band that looks similar to a early zip tie attached to the spindle. This should provide all the info. on the spindle- ie the build date and possibly the code as well.
As far as the option list, that is a GM list, but it does have 10-30 series and 40- 60 series as well as el camino options included. That is the truck master list. It is possible that it is for the camino but the have the car pattern and still have the 7/16 studs I believe. Another item, these trucks share alot of parts with camaros, chevelles and the big car line- mostly trim items, do a little comparison to the back up lights and cargo lights on 68 camaro- same stuff exactly. Also look at the gas trim and the clutch pedal trim from same cars it is the same. In saying this I also believe that it is possible that it could be an option in 70 simply because the disc technology was already in place but limited to high end cars but very rare. 71 was the first year it was standard and non option to get it on light trucks, when did it become become standard on cars? I could be like seat belts and other options early, rare and become standard either to save money or avoid law suits, just like the throttle rods and cables. Breaking motor mounts ushered in the change for cables and in 72 bb trucks the shift occurred early for motor mounts. My point is it is possible and feel if the tin tag decodes the correct dates coupled with the GM book paul could be correct.
special-K 12-18-2011 11:42 AM
The Chevy Truck parts book lists these as rear 70 C-1 w/disc brakes,along with 71 G-20 and 71 series-10 (exc. 4wd) and 10 required. I can see where it would appear that GM offered 5-lug disc brakes on '70 C/10s. I've seen a lot of things on this site I never knew was possible from what I had seen in 40 years of looking.
