-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   Looking for a basic air bag kit for my 65 stepside (https://67-72chevytrucks.com/vboard/showthread.php?t=498977)
Lowandwide65 12-18-2011 01:05 AM
Been searching like crazy here but since I have very little knowledge of air suspension I am still very lost. I am looking for a basic stock location airbag kit for my step side 65. Don't mind converting rear to disc or changing to higher lug count if I have to but I would like to just keep the stock control arms. I am not looking to make a show truck just something that can get as close as possible to the ground (love to lay frame but that looks like it cost a lot more than I am willing to spend). Rear is leaf springs and front is obviously coil. I would like a side to side movement, front, rear and up and down. Basically I would like to get bumpers and doors as low as possible with out all the fancey parts. Just want and nice very low hot rod that I can raise and lower at will. I don't mind piecing it all together, but a kit would be a lot easier to me. I took a look at brothers trucks but the tank and little parts don't seem up to par. From searching around I need at least a 5 gallon tank. My budget is a max of 2k as I need to save up to fix everything that the thieves messed up after they stole my truck. Anything helps guys. This was my first vehical so I am looking to finish what I started before she was stolen from me. Not sure what exact info is needed so sorry if I left out some obvious info. I am coming off from a fresh 87 mustang big block build so my Chevy truck knowledge is very rusty haha.
jmedero 12-18-2011 08:50 AM
Re: Looking for a basic air bag kit for my 65 stepside
With that budget you should be able to get a nice kit and still be under budget. Bag plate and cups up front @$300 with the bags. Rear bags @$150. You can do the accuair UV4 air manifold all day long for $450. You can do an AVS switch box for $120 and wire it in @$50 for fittings and air line. $150 viair compressor and @$80 for tank and your set. That's about $1300 for some nice stuff.
I just sold all my used stuff for $800, you can also find a used deal like that.
Call Justin at Scott's hot rods and he can set you up with what you need.
1 (805) 485-0382
justin@scottshotrods.com
N2TRUX 12-18-2011 01:08 PM
Welcome to the forum Lowandwide65. You have come to the right place in your quest for air suspension. I suggest you drill down through the threads in this forum and aqqaint yourself with the procedure.
Take a look in our Suspension Marketplace and Vendor Marketplace for some good deals. We have several vendors here that can help you through the process.
Lowandwide65 12-18-2011 02:35 PM
Hey thank you guys. Can't wait to dig into this project.
PBFAB.COM 12-18-2011 08:06 PM
As mentioned by N2TRUX there are several vendors and just as many options. If you are loooking for a simple and clean air system that will allow you to stretch your budget, get in touch with Delmo (he's a vendor here on the forum). He has been using a pretty slick manual valve set-up that is pretty trick.
Nate
jmedero 12-18-2011 08:51 PM
I've seen those the look slick. How fast do they flow? They look nice and simple to hook up, and the less wires the better. Lol
Sick5 12-19-2011 07:56 AM
Lowandwide65
make sure you take a look at all the threads there is alot of info. and alot of ways of lowring your truck.
oh by the way WELCOME to the furom
Lowandwide65 12-19-2011 11:49 AM
Ya thank you. I've been back and forth on just doing a normal lowering kit but air bags always seemed very appealing to me. Seems like a pretty straight forward install (well at least for what I will be doing). Not to mention the price to get it done is very nice on my wallet.
Lowandwide65 12-19-2011 11:57 AM
I do have one question for you guys. My truck has leaf spring in the rear. The few airbag kits I have seen are for coil spring. What do I need to do to run airbags in the rear? Been reading around but I am still lost on this one.
tubbedII 12-19-2011 01:41 PM
The answer will be based on how low you want to go. To lay frame, you're looking at a total redo in the rear, ditching the leafs all together. For a more mild set up, you can do an air over leafs, but you're still going to do all the typical things for a static drop on leafs (flip/drop shakels), but then add bags to the equation.
Lowandwide65 12-19-2011 09:42 PM
I was tooling around the porter built site and believe I am go with their deluxe kit. From adding front and rear I can come in at about 2k or a little more. Granted I still need the air equipment but their suspension parts look top notch and they advertise that you don't need to raise the wood bed floor.
PBFAB.COM 12-19-2011 10:11 PM
Shoot me a PM with your number and I will give you a buzz tomorrow to discuss the different options, and answer any questions you might have.
Nate
Sick5 12-20-2011 10:21 PM
so.. what ever happen did you get anything?
