-   The 1973-1987 Chevrolet & GMC Pickups Parts Board (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=5)
-   -   help cross member (https://67-72chevytrucks.com/vboard/showthread.php?t=5048)
chevy68388 03-05-2002 10:15 PM
help cross member
ok i hope some one can tell me how many crossmembers there are i have two one under the transfer case and one under the trans on my blazer and what is funny bout this is ive seen alot of the blazers that were all lifted the only have one and its on the trasfer case
dr_mi 03-05-2002 10:29 PM
You should have only 1 crossmember (at least that's how my 79 blazer is) it's what the transfer case adaptor (between trans and t-case) bolts to. Owner before you might have put one in to act as a skid plate.
[This message has been edited by dr_mi (edited March 05, 2002).]
monypit 03-06-2002 07:40 PM
you will have two if your blazer is like mine. I think it was for a skid plate or something because it doesn't have anything else hooked to it.
chevy68388 03-06-2002 08:01 PM
well im pulling the one off cause i dont need it and it messing with the lift
Fast68Chevy 03-06-2002 09:41 PM
pull the one under the transmission, not the one under the transfer case, or.,,,,,
