-   -   rear center and front tbi adapters which do i need? (https://67-72chevytrucks.com/vboard/showthread.php?t=506391)
Scott26 01-30-2012 09:32 PM
Im wanting to know the difference between front mount rear and center mounts. I Have a stock 1986 4 barrel quadrajet intake, and im looking to buy a carb to tbi adapter but i need to know which of one i need. thank you. And is there a adapter that is ca legal?
Turbo85GMC 01-30-2012 10:18 PM
Re: rear center and front tbi adapters which do i need?
There is an actual GM carb-to-tbi adapter that they used on the 454's with TBI. (afaik they never made a big block TBI intake, they just made the adapter) It has nice smooth transitions, not like the flat plate adapters.
Just my $0.02, ymmv.
Turbo85GMC 01-30-2012 10:22 PM
http://www.ihonlynorth.com/forums/at...ead-bore-1.jpg
http://www.ihonlynorth.com/forums/at...ead-bore-2.jpg
FritzA 02-04-2012 02:27 PM
The rear offset is more like the stock tbi manifold. No idea why GM made it like that. The middle ones are for people doing conversions who won't be changing their throttle cable which went to the center in the quadrajets.
BLE 'BURBAN 02-05-2012 03:57 PM
These on the 454 were also plumbed into the heater lines to keep the tbi throttle plates from icing up in extreme cold conditions.
