77 C10 LT1 power steering question
I have a 77 C10 2wd with a LT1 crate motor in it. I want to add power steering to the truck. Currently the only accessory I have is the alternator and it is mounted low and to the left of the motor with a single belt that is driven off the crank pulley. My question is, can I get a stand alone bracket to mount the power steering pump and if so, are there double bottom pulleys available to run the PS pump?
Thanks! |
Re: 77 C10 LT1 power steering question
is this a second gen lt1? if so you can get an accessory bracket and factory ps pump from any early to mid 90s b body car impala caprice roadmaster, or camaro trans am which has a little different acc set-up im gonna do the swap soon my only ? is is the powersteering pump strong enough for our trucks?
