-   -   62 C-10 Steering Gear Box (https://67-72chevytrucks.com/vboard/showthread.php?t=508929)
K98AL 02-14-2012 09:27 AM
I've got the usual "drives like a clown car" problem with my '62. I'm thinking the steering gear box is bad, but how do you know? (I've never had an old Chevy that wasn't pretty well worn out, so I'm not sure how much "play" should be there. What about the Pitman arm? Thanks for your help!!!
awbrown 02-14-2012 09:56 AM
Re: 62 C-10 Steering Gear Box
no play is good !! if you find any loose components replace them then get an alignment ,last but not least tires , being worn or mismatched will do the same thing ....
1Bad62Pro/Street 02-14-2012 10:05 AM
It shouldn't have alot of play in it.
How to adjust the steering gearbox
http://www.chevytrucks.org/tech/steering_box_adjust.htm
34-1005-Z MANUAL STEERING GEAR-REMAN
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=82
http://www.lmctruck.com/icatalog/cbe/865w/0082.jpg
