-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   66 front suspension Q's (https://67-72chevytrucks.com/vboard/showthread.php?t=514094)
59weasel 03-13-2012 02:38 PM
ok so the daughters ride will be home soon...want to change it from 3/4 ton to 1/2 ton. rearend is easy... but what should i look for for the front. 5 or 6 lug doesn't matter, but i already have a 6 lug 1/2 ton rear just waiting so i'll probably stick with this route. i would like to do something from '73 and up for the front due to the rubber bushings and such. can i swap a complete front suspension with out a ton of work? i know there will be some stuff to do, but i'm talking like when i put the camaro sub frame under my '59. (kinda major surgery to me.) any thoughts or ideas? i was kinda hoping to find something at our local u-pullit yard. (at least the crossmember and arms an such)... thanks guys.:chevy:
SCOTI 03-13-2012 04:25 PM
Re: 66 front suspension Q's
The 73-87 front suspension package will interchange/swap over to your 66 w/minimal issues. You can also swap just the suspension pieces to your existing 66 x-member.
To match the 6-lug bolt pattern of the rear, just use aftermarket 6-lug disc brake rotors available here from supporting board vendors. They're a direct swap for the 5-lug rotors.
59weasel 03-13-2012 10:37 PM
Thanks SCOTI. Just swapping A arms and spindles and such is nice to know.I think I'll spend a couple days Google surfing. And here also of coarse!:metal::chevy:
