-   -   Carb help (https://67-72chevytrucks.com/vboard/showthread.php?t=520358)
TigerDMD 04-18-2012 08:48 PM
Carb help
I need some recommendations. I think my carb is having some issues. Im thinking about replacing it and possibly replacing the air cleaner - trying to make it all look as nice as the exterior. Anyway, what are my options for carb replacement (other than original replacement)
http://i358.photobucket.com/albums/o...0/DSC03005.jpg
I don't hav a current of my engine bay, but here is the rest of the truck
http://i358.photobucket.com/albums/o...s/9dc25a60.jpg
Wrenchbender Ret 04-18-2012 10:44 PM
Re: Carb help
That is a Rochester Mono-jet carb. They are good dependable economical carbs. They do need cleaning & new gaskets ocasionally. Put a kit in it or get someone familiar with them to do it. Do not exchange it for a "reman". They often dont match the application & most of the time are not right. Make sure the link from the throttle shaft to the step up rod does not fall out of the hole. If you should go the exchange route DO NOT turn in the old carb till it is up & running & you are satisfied.
camaney 04-18-2012 11:34 PM
Re: Carb help
i have a holley with the number 1940 stamp on it one barrel carb and like it
