-   -   trailing arm bushings (https://67-72chevytrucks.com/vboard/showthread.php?t=520864)
jessewebb 04-21-2012 11:36 PM
Thinking about replacing mine since I'm that close to them. I'm down to the frame. Have everything off. The bed,cab front end engine and tranny. Pressure washed the frame. Gonna put the 2" lowering blocks under it. So I figured why not change the bushings. My questions are. How big of a job is it. Is there any tricks I need to know about. Is there an easy way. Do the have to be pressed back in. I've never attempted this before. But I've never dismantled a truck either. But I'm doing it now. Thanks for any advice in advance. Pete
gysgtc 04-22-2012 06:15 AM
Re: trailing arm bushings
I used an electric drill and kept drilling into the rubber part of the bushing. Then used a big socket and hammer to pound out the old bushing. The new one does not need to be pressed in.
cdowns 04-22-2012 07:21 AM
i use a torch an burn em up// always used a cclamp to get them in
jessewebb 04-22-2012 07:40 AM
Guess I'll have to do the drill approach. Don't have a set of torches :( thanks guys for the info.
BuiltwithIvy 04-22-2012 11:58 AM
i would go pick up a cheap propane torch from Home Depot, will make the job much easier, but will also be kinda messy and smelly, so do it outside
jessewebb 04-22-2012 12:21 PM
I've got one of those and its sitting outside. Today would be a good day for that. I have another question I ran across while looking for the bushings. I seen to types of bushings. One is the rubber type and the other is a rubber bushing inside of a steel tube looking thing. On Bowtie Bits website. I was just wondering where that one went? Anyone know?
jessewebb 04-22-2012 12:49 PM
3 Attachment(s)
here some pics of whats on my truck
jessewebb 04-22-2012 12:54 PM
heres the two that Bowtie Bits are showing .
The first picture has this under the picture
1967-72 Trailing Arm Rubber Bushing Rear
$12.00
jessewebb 04-22-2012 12:58 PM
2 Attachment(s)
the second one has this under it
1967-72 Stabilizer Bushing Kit Rear 1/2-ton
$12.00
The third picture has this
1967-72 Trailing Arm Bushing Kit Red Rear
$17.00
jessewebb 04-22-2012 01:02 PM
I'm assuming 2 and 3 are the same, just bifferent colors. but now I'm not sure if I need #1 or #2 ?
gysgtc 04-22-2012 03:21 PM
I used the black ones
MLB57 04-22-2012 06:38 PM
pic 1 is like original, beat the old one out and drive that one in. Pic 2 you have to reuse your housinig drill or burn it out, pic one alot easier to change
gysgtc 04-22-2012 07:37 PM
When I did mine the outer metal sleeve stayed in the trailing arm.
jessewebb 04-22-2012 07:52 PM
By the looks of the rust on the bolts and the dry rotted rubber around the outter edges, they defiantly need changed and gonna be a job :(
chevytruckluver 04-22-2012 11:56 PM
by the looks of the old bushings, you should replace the whole thing by using the original type. I would not put a new poly in the 40 year old shell of the old bushing.
When I had my arms powder coated I hammered the old ones out pretty easily. I bought the original type and used a large vise and some WD-40 to press them back in.
good luck
RexDodge 04-23-2012 12:14 AM
My vote would be to drill em out. I just did mine. Actually a very easy job. Sic em...
jessewebb 04-23-2012 06:26 AM
Looks like the hardest part is gonna be getting the bolt broke loose. Doesn't look like there's much bushing left. Thanks for the info. Might get a chance to tackle it today since old man winter decided to show back up. 70 one day and 5" of snow and 30 the next day :(
eric8 12-13-2013 03:40 PM
I need to do this job but my truck is not torn apart like the original poster's is. What needs to be removed to let the trailing arms drop down?
trkfrk 12-13-2013 05:49 PM
$12.00
That's a great price. I paid double for the same ones. LOL
gysgtc 12-13-2013 06:10 PM
I drilled mine.
Jeff_Fall_City 09-18-2014 01:12 PM
I just wanted to say thanks for the advice CDOWNS! I burned mine out last night - didn't take more than 20 minutes for both with my propane torch! After I pulled out the centers I lit em up again and burned out the residue. This forum is the best!!
bean 09-18-2014 04:52 PM
just did mine. used the cheap propane bottle method and heated them up... pulled right out. i went ahead and just cut off the old bolts.
