SPID - Canadian C80 option?
My 69 C10 has a C80 option listed on the SPID (inside glovebox). It's faded so bad I can't read all of it. It reads FRONT DOOR OPERATED .... There is something else there. Anyone able to read theirs?
Appreciated, Ron :chevy: |
Re: SPID - Canadian C80 option?
Ron, on this website it says dome lamp switch.
http://outintheshop.com/options.html EDIT: just found another website that says. C80 : SWITCH, JAMB, FPT DR C81 : SWITCH, JAMB, RR DR |
FRT DOOR OPERATED but I can't make out the end. |
You've got a unique one.
I checked out the SPID picture thread and all the C80 descriptions said DOME LAMP SWITCH. |
maby it means that the front door operates the dome lamp when it opens.
Never seen this description before. Everything I have is "DOME LAMP SWITCH" for C80, we are hoping to see another label with the same description that we can actually read.
Jeff |
3 Attachment(s)
Ron,
From what I can dig up in my stuff C80 DOME LAMP SWITCH seems to be it. Worked on the picture posted and it looks like the only thing after "operated" is a rub/smudge. Here is what it looks like to me. If you would like I will work another picture taken at high resolution and emailed to me. PM for address. Also what assembly plant built your truck? |
Why isn't it available in a CST? Was it standard equipment?
I'd go with door jamb operated dome light. The following are more recent GM codes.
C80 : SWITCH, JAMB, FPT DR C81 : SWITCH, JAMB, RR DR C87 : LAMP, INTR, QTR COURTESY C88 : LAMP, INTR, RR HEADER, COURTESY C89 : LAMP, INTR, QTR, SINGLE READING C8A : PAINT SPECIAL, (WHITE) C8B : PAINT SPECIAL, (SILVER MET) C8C : PAINT SPECIAL, (BLACK) C8K : PAINT SPECIAL, (MED GRAY MET ) C8T : PAINT SPECIAL, (DK MAPLE RED MET) C90 : LAMP, INTR, FRT AND RR DRS, COURTESY C91 : LAMP, INTR, ROOF, COURTESY C93 : LAMP, OPERA C94 : LAMP, DOME, DELAYED C95 : LAMP, INTR, ROOF, COURTESY AND DUAL READING C96 : LAMP, INTR, QTR, COURTESY AND SINGLE READING |
Probably is a smudge, the truck was used for a painting company I worked for before I bought it! And the doors do operate the dome light. |
What would the FPT stand for? Ron |
Jeff |
So everyone that has a Oshawa assembled truck, especially a '69, please check your SPID. If you are not sure the plant code is 1. VIN... CE349 1 100001 example number |
Went through my SPID picture collection. Seven from 1, Oshawa assembly plant. Only one, a '71, had C80 listed and it was "DOME LAMP SWITCH".
Mine has the option in the truck (also on the original order form for $4.00) but doesnt show on the SPID. Also an Oshawa truck but 1972.
It was part of the Custom Deluxe Package thats why its not on the SPID. |
I should have caught that Tim, mine is a custom deluxe. Thx
| All times are GMT -4. The time now is 05:47 AM. |
