-   LSx Swaps (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=206)
-   -   how close is to close (https://67-72chevytrucks.com/vboard/showthread.php?t=522570)
GMC70c20 05-02-2012 03:29 AM
I am just about to order the parts to build my 2006 6.0. I already got the heads (stock ls3 heads) I am going to replace everything minus the crank pistons rods and block. I was going to check my piston to valve clearance when I put it together, what I need to know is how close is to close?
code4 05-06-2012 10:48 AM
Re: how close is to close
.080, a lot of variables though. You must be milling the heads & a huge cam to be worried. Check this thread out:
http://ls1tech.com/forums/generation...clearance.html
GMC70c20 05-07-2012 02:29 AM
I was just going to take enough off the heads (if any) to get the warp out and the came is only .563/.542 lift. I have no idea how much clearance will be there I was just curious how close I could get safely.
