Full Floating Dana 60 Question??
Do the axle shafts on a Dana 60 have c-clips? I am wondering because I will be putting a Powr-Loc posi in soon and was wondering how you would get the c-clips back on when the posi carrier is back in because the posi carrier housing is solid all the way around. Am I missing something or what? Thanks
HotRod |
dana 60 is full floater, you can unbolt the axle at the end of the hub and pull it straight out then push it back in, line up the splines, and put the bolts back in (no c clips)
Is there a gasket of some sorts at the end of the hub on the inside or something? Thanks
HotRod |
my eaton just has a little flat metal plate... i live on a hill and never had a problem with leaking, so i dont think there's a gasket
The only gasket is on the inside of the hub. Should only have a flat metal plate for the shaft, at least that's all mine(dana 60) had when I pulled a shaft.
