th350 not shifting
ok guys me and my dad just rebuilt my tranny due to a blown sprag. it has a manual valve body no automatic features whatsoever first gear and reverse work just fine but when is try to shift from first to second its like 2nd gear isnt applying same thing when i go to 3rd it seems as though its stuck in first. i just pulled the valve body off to make sure none of the valves were sticking and they all seem to be moving freely. someone help pleaseeeeeeeeeeeeeeee
Its been a while.....but when you convert to manual valve body they give you a special plug to replace vacuum modulator.
Next would be the Governor might not be installed correctly or faulty |
i think u mighta hit the jackpot on the governor deal i know the plug is there for the modulator. i guess its time to bolt the valve body back up and check out that governor
anyone have any other ideas b4 i put the valve body back on and seal the pan back up
I vote for the governor also.
i wish i woulda got a 2nd opinion b4 i pulled the valve body and took a bath in tranny fluid but thanks very much for the help guys i will let y'all know what happens
well i pulled the governor and everything seems to be just fine. i still didnt put the valva body back in hoping its not a more sever problem. if anyone else can help let me know
What ever you do, let me know. I rebuilt my TH350 last summer and it isn't shifting into 3rd. I does shift from 1st to 2nd but then it won't shift up to third. I have almost given up on it and I'm just about to take it into a shop.
Have you figured anything out yet?
