-   LSx Swaps (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=206)
-   -   wire routing (https://67-72chevytrucks.com/vboard/showthread.php?t=524833)
thump16 05-15-2012 10:53 PM
wire routing
Did you guys run the purple starter wire (truck original) around the back of the engine to starter or up front along the oil pan bracket which is the same route as the main battery power for starter?
Dustytrix 05-15-2012 11:08 PM
Re: wire routing
I ran mine around the back, but I guess you could go either way if it was long enough. I just started my swap so I am learning too.
gringoloco 05-16-2012 10:45 AM
Re: wire routing
I think either way would be fine, but the shortest, safest, best-looking route would be my choice.
awhite4557 05-17-2012 09:53 AM
Re: wire routing
I ran mine around back and down to starter.
OneOffStroker 05-23-2012 08:14 PM
Re: wire routing
I have a floor mounted shifter (B&M Unimatic) and the wire goes from my key down to the shifter's NSS then runs down and out with the trans wiring and sneaks up on the starter from behind.
chevydog66 05-29-2012 09:47 PM
Re: wire routing
Around the back for me. Straight down from wire gutter on top of firewall with black wire loom around it.
BR3W CITY 05-29-2012 10:04 PM
Re: wire routing
from the front, tucked in
