-   Racing and high performance (trucks haulin more than hay) (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=60)
-   -   Rebuilding Holley 750 list 9773 (https://67-72chevytrucks.com/vboard/showthread.php?t=528715)
72 Super 06-10-2012 11:29 AM
I have a Holley 750 List 9773. It is about 20 years old :) It still runs great, but is starting to leak. I have never rebuilt one myself, but I think I am going to give it a try. I have replaced power valves, jets, set floats etc
My questions are:
Should I soak the parts except the base plate in ? If so what is the best to use?
I am going to use a Holley Trick kit # 37-485 and will replace the floats as well. Anything else I should consider?
Thanks in advance,
Ray
team39763 07-08-2012 06:34 PM
Re: Rebuilding Holley 750 list 9773
My truck has run it's fastest with my old 4779 Holley 750. It had a HOLLEY brand HP main body, jet extensions, and 1:1 linkage. I was in need of money so I sold it, but I'm about to build another one the same way. I used the plastic/nylon gaskets for the N&S and fuel bowl bolts.
