How much is
this bed worth the guy want's 400 for it ....No rust and it's straighter than the one I have .....
another pic
side
one more
last one
They range in price. Is that a short or a long bed? I would buy it in a minute if it was short and here in Virginia. Wootdog
Long bed.... But that's what i got...
I would take a good look at it. If the bed bottom is steel and is flat, then I would go for it. It looks pretty strait, but I would check the under side of it also. They dont have to set on the ground verry long to start rusting all of the cross sills. WES www.ClassicHeartbeat.com
I would get all the junk out of it and check the floor over, the will rust pretty quick too, they hold water b/c the drain hole get plugged up with junk. Just my $.02.
i second rangernsk's comment .... clean out all that junk and see what the bottom looks like .... the way it is now .,..its just holding moisture to it all the time.... im sure he wont have a problem with you cleaning it out even if you dont decide to buy it
that was my 2 cents |
