-   -   Tru-Ram Exhaust manifold fit? (https://67-72chevytrucks.com/vboard/showthread.php?t=531620)
x1buellist 06-29-2012 12:00 PM
Any idea if the Tru-Ram exhaust manifold will clear the frame etc on a 66 C10 with a 327
http://www.speedwaymotors.com/Tru-Ra...olds,3823.html
MalibuKasey 06-29-2012 12:14 PM
Re: Tru-Ram Exhaust manifold fit?
depends if your motor mounts are in the front or rear location on the frame. If they are in the rear you will be fine. If they are in the front you can make it work... But it has to be a SUPER TIGHT 90 degree bend right out of the Rams horn.
x1buellist 06-29-2012 12:30 PM
Thanks, can you tell from this picture whether mine are in the front or rear location?
https://lh4.googleusercontent.com/-y...0/IMG_0055.JPG
Dinos63 06-29-2012 12:47 PM
yes they will fit , there is a picture on my thread they sound nice too
padresag 06-29-2012 12:58 PM
looks like you are in the rear hole. there should be an open bolt hole just in front of the perch on either side that will line up with the other two that are in the perch, just as if you moved the perch forward it would bolt in there
ron
hopped up 06-29-2012 01:01 PM
those are sweet! let us know if you get them and any problems with the fit. i wanna put those on mine too.
x1buellist 06-29-2012 01:54 PM
Ordered them today. Wasn't really ready to tackle the engine compartment. Been working on the frame and back of the truck but I want to get a new exhaust system installed so I needed to have the manifolds installed for that to happen.
