-   -   flowmasters on 454? (https://67-72chevytrucks.com/vboard/showthread.php?t=538432)
wwj75c30 08-14-2012 06:51 PM
flowmasters on 454?
do any of you guys run 10 series single chamber flowmasters on your 454? im looking into new mufflers i was thinking about those. i like being able to be heard.right now its straight pipes with turn downs under the bed.
so if any of you guys are runnin them what do you think about them?
wwj75c30 08-14-2012 08:45 PM
Re: flowmasters on 454?
i know somebody has to be running those flowmasters
cory d 08-14-2012 10:15 PM
i would much rather run glass packs
wwj75c30 08-14-2012 11:10 PM
i already had those i hated them with a passion. sounded like a fail.
but thats my opinon. i like flowmasters or straight pipes like i have right now
75 big 10 08-15-2012 12:12 AM
I'm running 40 series on mine and it's plenty loud. If you wan.t to go that route look into the summit street and strip mufflers. They run 30 bucks each and sound real aggressive. I just put a set on my 76, for the price and sound I'm happy.
cory d 08-15-2012 12:26 AM
if you ike the crisp crack of straight pipes i wouldnt go with anything that flowmaster makes. on a stock engine they sound like chewbacca and with stock exhaust pipes and scats it sounds like a boat. my summit welded muffler(flowtech so another holley compony) sound pretty crisp and dont have a constent drone. im not sure what 10 are like but every lifted truck in my hick town has a flowmaster 40 and i just dont care for them at all
1986gmc 08-15-2012 01:01 AM
Never can go wrong with flowmasters. ive always but them on everything ive owned
tinydb84 08-15-2012 01:07 AM
EBay has a knock off version for $35 bucks. Search single chamber mufflers.
misslemanid 08-15-2012 02:38 AM
I run the 10's on my 77 burb with a 454. They sound pretty good. Deep and a little throaty on idle and they're not as annoying as glass packs IMHO. The only thing that I think that would make them sound better is headers as I run stock manifolds. Gotta save my pennies I guess.
INSIDIOUS '86 08-15-2012 03:12 AM
Look up spintech on YouTube find the black chevelle.
Spintech nuff said
cumminclouds 08-15-2012 09:04 AM
Spintech nuff said
That was exactly what I was about to say, spintech sounds Great on 454's.
I had a set of 40'series on my truck and it is cammed, aluminum head 454 and honestly I didn't like the sound of it.. It didn't give the motor any lope it was just constant noise and alot of noise was coming through the muffler into my cab compared to others I've had...
Moostifer 08-15-2012 10:10 AM
had them on mine... I'm now using the 30's. no difference in sound at all (but my motor isn't stock either), just got more torque from the added back pressure.
Redcap 08-15-2012 10:52 AM
A complete myth.
Moostifer 08-15-2012 12:16 PM
Originally Posted by Redcap (Post 5540163)
A complete myth.
my dyno pulls prove you wrong. sorry :lol:
INSIDIOUS '86 08-15-2012 01:27 PM
A complete myth.
True, put a wet rag in your mouth and tell me if you run a marathon faster.
No engine made likes back pressure. Your gain in torque was possibly from increased exhaust velocity. This is why some engines will run better overall with a 2-1/5 inch pipe over a 3 inch pipe. There is more exhaust velocity a lower rpm/smaller engine will get more flow from a small pipe over a 3" pipe!
Apply this to cyl heads as well on the intake port runners
Billett 08-15-2012 02:07 PM
I like the sound of spintechs or the super 44's, but look into cut-outs as well.
wwj75c30 08-15-2012 02:38 PM
you think theyd sound good? i already have headman headers and a rv cam.
i think ill run the 10s for now i already had the 40s and i got bored with them
i think ill go to spintechs when i get a bigger cam intake and carb
wwj75c30 08-15-2012 02:54 PM
i might just run 40s or super 44s and run cut outs right after my headers for when i go to pass someone or just feel like bein loud lol
Redcap 08-15-2012 04:21 PM
Your dyno pulls didn't improve because of 'back pressure', kiddo. If you actually believe that drivel, you have a lot of research to do.
Firebirdjones 08-15-2012 04:59 PM
Yep, ran the single chamber flow masters on my 79 454 pickup along with headers and a custom bent 3" dual system with an "H" pipe for many years. As I got older I got sick of the noise however, I could be heard coming a mile away :lol:
Recently I swapped to a 502. Since I was not interested in how that might of sounded I pulled the single chambers off and installed a pair of Pypes Street Pro's. Couldn't be happier, much more livable.
I run the super 40's with a 3" "X" pipe system on my 454 chevelle. It's a bit on the loud side but I don't drive it much.
wwj75c30 08-16-2012 04:24 PM
i could use a 502 in my dually lol
baclay9 08-16-2012 08:23 PM
Here are Spintech Pro Streets behind my mildly built 468. It has an H-pipe.
wwj75c30 08-16-2012 10:01 PM
my duallys either getting a built big block or built 12v or 24v cummins
dlhughes2005 08-16-2012 10:37 PM
BBC with Spintech Exhaust - YouTube
Sounds great! I also plan on running the spintechs behind my big block, if I ever finish the damn thing.
GM-power 08-17-2012 11:24 AM
Well I have a single in/out flowmaster original 40 on my 350. Its bored. 040. I think it sounds good. Its real low and throaty. I think 40's would sound good on your BBC.
