-   All 4x4 Tech & Off Roading (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=30)
-   -   NP 241/NV4500 input shaft help (https://67-72chevytrucks.com/vboard/showthread.php?t=538595)
SunSoaked 08-15-2012 06:45 PM
Experts please chime in-
I'm putting a NV4500 in which I havent got yet. I am also going with a NP241.
I found a 241 wit 27 spline input. Does the NV4500 come with a 27 and 32(?) spline?
I like the $100 asking price on the T case, but dont want to end up with a mis-matched shaft with the 4500.
obijuan 08-15-2012 07:53 PM
Re: NP 241/NV4500 input shaft help
the GM nv4500 is exclusively 32 spline. you will need to either buy a 32 spline tcase, or swap in a 32 spline input into that cheap 241.
SunSoaked 08-15-2012 09:36 PM
Actually, after some further online research, it appears there are 27 and 32 spline 241s. The 350s/700s used the 27 spline. The 400s/and all 5 speeds used the 32 spline.
New 32 spline shafts average $150. Once again it appears I'm better off to keep searching for the right one to begin with.
Patience is not my best virtue.lol
obijuan 08-15-2012 09:43 PM
a passenger drop 32 spline mechanical speedometer np241 is pretty damn hard to find. its 1989 3/4 ton burb and manual trans k5s. you might be better off learning how to rebuild a 241 and swap a $150 input in it.
