-   Suspension (https://67-72chevytrucks.com/vboard/forumdisplay.php?f=25)
-   -   longer studs? (https://67-72chevytrucks.com/vboard/showthread.php?t=541609)
mongoose 09-05-2012 02:41 AM
longer studs?
looking for some longer studs using the stock knurl dia.
i haven't been able to find any.. I drilled out the back for bigger ones but don't want to drill out the fronts if i don't have to..
anyone actually make one?
canadian trucker 09-05-2012 11:21 AM
Re: longer studs?
I once had to get longer ones for the front.
Pressed out the original, walked down to Lordco......... or was it NAPA, either one.
They will measure it up and look thru their book for a longer one.
Or measure it up yourself, if you have a digital caliper and look on summit's website for a part number, then drive down to Mopac or Lordco and get some.
If I remember correctly for a 1.25" front rotor its a 0.620" knurl
But better double check
Hope it helps
KQQL IT 09-05-2012 12:35 PM
Re: longer studs?
Summit racing
http://m.summitracing.com/search?key...0studs%201%2F2
El Campo 09-05-2012 12:55 PM
Re: longer studs?
Moser Engineering 8250 - Moser Engineering Wheel Studs
http://www.summitracing.com/parts/MSR-8250/
These are the ones that I got from Summit. They have a 0.625 knurl (versus the 0.619 stock one) and are 1.938 inches long (underhead length), perfect for my billet wheels. I have the HD rotors up front. Dorman or anyone else that I could find does not make a longer one, I did a crap load of research for this. I am putting these in both the back and the front. Plus they are from Moser so you know they are very high quality. Hope this helps.
El Campo 09-06-2012 09:58 PM
Re: longer studs?
Before you rush out to by these I need to check and make sure that they work on mine! Got them today from Summit and they are not threaded up all the way to the head. There is 3/4 of an inch under the head that is not threaded. I will check on Monday to see if they work fine or not
El Campo 09-19-2012 11:50 AM
Re: longer studs?
Just an update on the studs. These worked perfectly for my billet wheels. Didn't have to drill out the rotors or antthing
