-   -   4.5/6 Drop, Tire size rollin on 20's (https://67-72chevytrucks.com/vboard/showthread.php?t=542442)
HotRod C/10 09-10-2012 12:21 PM
What do you recommend for a 4.5/6static drop 20x8.5 5.25BS and 20x10 5.5 BS? Please post pics here if you like....... THANKS!
LEX 09-10-2012 12:26 PM
Re: 4.5/6 Drop, Tire size rollin on 20's
Seems like a lot of folks here are running 255/40 and 295/40.
lolife99 09-10-2012 12:42 PM
X2.
Toyo Proxes are a good choice for those two sizes.
http://www.discountedwheelwarehouse....ST_2_Tires.cfm
original-71 09-10-2012 02:17 PM
you can do 255/35/20 and 275/35/20 depending on how how much side wall you like.
HotRod C/10 09-10-2012 02:25 PM
I like how yours sits, what tire are you running?
original-71 09-10-2012 02:41 PM
the 255/35/20's front and 275/35/20's rear
HotRod C/10 09-10-2012 02:54 PM
What brand?
original-71 09-10-2012 03:04 PM
Originally Posted by DSALRAM (Post 5585231)
What brand?
mine are Nitto"s
CC69Rat 09-10-2012 03:37 PM
I like a 255/45 and 295/45
.. but, that's just me.
LEX 09-10-2012 03:51 PM
I'll probably do 295/45s in the rear if I do 20s.
HotRod C/10 09-10-2012 10:35 PM
anyone ran 285/40r20 before.......its a good happy medium sidewall at 4.48".
Pro Performance 09-10-2012 10:42 PM
When we usually setup tire and wheel combo's, I run a 285/40/20 in the back with a 245/45/20 up front. That gives you the staggered look and the tires are the same height. But, it also comes down to personal opinion. Those sizes I mentioned are availble in the Nitto 420S.
As for backspacing, the numbers you mentioned are good, considering you have the wider rear end in your truck that came in the later 70-72 C10's. Your signature says 68, but did you swap rear ends? If not, you would run around a 4.75" BS on the rear 20x10. Or run a spacer depending on what wheels you are looking to go with.
Here is an image of a 285/40/20 Nitto 420S.
http://i402.photobucket.com/albums/p...angerRT008.jpg
Hotrob72 09-10-2012 10:46 PM
ECE 4.5/6 dropped on 20x10 295/40 & 20x8.5 255/40
lolife99 09-11-2012 07:40 AM
Perfect!^^^
HotRod C/10 09-11-2012 12:23 PM
Originally Posted by lolife99 (Post 5586552)
Perfect!^^^
Thats the one!
HotRod C/10 09-11-2012 12:28 PM
Do you have any pics of them mounted on customers trucks?
Pro Performance 09-11-2012 12:55 PM
I don't have any pictures of the trucks we have done with those particular sizes. However, I did find this later model truck on the forums here. Not sure who owns it, but hopefully they don't mind.
The rear tire is the 285/40/20. The front is a 255/35/20 which is shorter than the 245/45/20, since that 245 is the same height as the 285.
http://i41.photobucket.com/albums/e2...s/DSC00861.jpg
HotRod C/10 09-12-2012 12:29 PM
Any others with pics?
original-71 09-12-2012 01:52 PM
i need new pics of my truck but heres one. E.C.E 4-1/2 and 6 drop kit with a 1/2 block also in the rear. You can do 6-1/2 in the rear with no c-notch.
HotRod C/10 09-12-2012 02:14 PM
Very nice stance
HotRod C/10 09-12-2012 02:15 PM
Id like to see an a$$ shot of that to see what the tire width looks like.....
original-71 09-12-2012 02:24 PM
2 Attachment(s)
i think i can help you with that :D but theses were taken before i lowered it a 1/2" more now the rear sits pretty even with tire :chevy:
HotRod C/10 09-12-2012 02:31 PM
That last one is MONEY!
original-71 09-12-2012 02:35 PM
the 35's arent bad of a ride either i here good things about the 40's and may go that route later, i wish someone made a wide 35 to give it that bubble on the outsides.
HotRod C/10 09-12-2012 02:43 PM
http://discounttires.com/product_det...E=&prodID=6613
